[GRASS-dev] Re: gui startup bug (new locn by epsg code)
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Jan 30 13:00:12 EST 2007
Hello Maris
On Tue, 30 Jan 2007, Maris Nartiss wrote:
> Hi,
> I can confirm this bug.
> Problem is - this EPSG code requires aditional user input from comand
> line - just try to run "g.proj -c proj4=+init=epsg:2258
> location=EpsgBug" whithin GRASS session and g.proj will ask for
> aditional parameters. As current tcl/tk code does not open xterm for
> g.proj operations, it stucks on waiting user input from nonexisting
> xterm app.
The attached patch will run g.proj in a terminal Window in case it needs
to prompt for user input. I think it is a good workaround for the time
being?
> IMHO this should be fixed in g.proj first to make it independend from
> interactive comandline usage and then startup screen can be fixed to
> use new g.proj feature.
How do you propose it is fixed? It is arguable IMHO that the problem is
not in g.proj. It will only interactively prompt if *partially complete*
datum information is passed to it. If the GUI passes projection
information that has been pre-processed so the datum part is OK, then it
will not interactively prompt. This was discussed in an earlier thread.
Paul
P.S. A similar patch should probably also be applied to file_set.tcl.
P.P.S. The recent little usability improvements to gis_set.tcl (new
location automatically selected etc.) are great! Well done.
Index: epsg_option.tcl
RCS file: /home/grass/grassrepository/grass6/lib/init/epsg_option.tcl,v
retrieving revision 1.7
diff -u -r1.7 epsg_option.tcl
--- epsg_option.tcl	24 Jan 2007 04:51:12 -0000	1.7
+++ epsg_option.tcl	30 Jan 2007 17:37:54 -0000
@@ -230,6 +230,7 @@
 	global env database
 	global location
 	global mapset
+	global mingw
 	#test for valid WIND file
 	if {[catch {exec g.region -p}] != 0} {
@@ -288,16 +289,13 @@
 		# create new location from EPSG code
-		catch {exec g.proj -c proj4=+init=epsg:$epsg_code location=$epsgLocation} errMsg
-		if {[lindex $::errorCode 0] eq "CHILDSTATUS"} {
-			DialogGen .wrnDlg [G_msg "WARNING: Error creating new location"] warning \
-			[format [G_msg "Error creating new location from EPSG code. \
-			g.proj returned following message:\n\n%s"] $errMsg] \
-			0 OK
+		if { $mingw == "1" } {
+			exec -- cmd.exe /c start g.proj -c proj4=+init=epsg:$epsg_code location=$epsgLocation
 		} else {
-		        set location $epsgLocation
-		        set mapset "PERMANENT"
+			exec -- $env(GISBASE)/etc/grass-xterm-wrapper -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh g.proj -c proj4=+init=epsg:$epsg_code location=$epsgLocation
+		set location $epsgLocation
+		set mapset "PERMANENT"
 		# restore previous .$GRASSRC
 		if {[file exists "$database/$tempdir/$GRASSRC"]} {
@@ -309,16 +307,13 @@
 		set env(GISRC) $curr_gisrc
 	} else {
-			0 OK
 		} else {
