[GRASS-dev] how to display a vector map for d.path in gis.m?
Tue Jan 30 17:04:32 EST 2007
Glynn Clements wrote:
> Hmm; it might be useful to have some means of automatically generating
> the corresponding g.parser description for a given command. There are
> probably quite a few scripts whose options are (almost) identical to
> an existing command. I'll look into it.
I've extended G_parser() with a --script flag, which writes out a
script with g.parser syntax to mimic the behaviour of the module. This
shoud make it easier to write scripts which mimic an existing command.
