[GRASS-dev] small patch for lib/vector/transform/
Dylan Beaudette debeaudette at ucdavis.edu
Fri Jun 1 18:29:59 EDT 2007
On Friday 01 June 2007 12:33, Dylan Beaudette wrote:
> I needed some functionality to print the transformation matrix, very simple
> patch - it might be useful to others.
> It prints out the matrix along with a small note:
> Transformation Matrix
> 28155.882288 0.013530 1.002469
> -5301.399323 0.997547 -0.009172
> the patch is attached.
> Perhaps diagnostics like this might be a general use.
ack. attached is a better version, with the ordering better spelled out. Note
that this matrix output is in the format that other applications like R and
PostGIS create / expect.
cheers
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
Type: text/x-csrc
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070601/d02d01e8/print_matrix-patch-transform.bin
