[GRASS-dev] QGIS winGRASS blank space problem
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Jun 4 11:46:16 EDT 2007
On Mon, 4 Jun 2007, Markus Neteler wrote:
> Hi,
> a friend told me that with the latest QGIS release candidate,
> there is a winGRASS problem:
> $ v.rast.stats vector=CEA_riserve raster=CEA_slope colprefix=delete
> c:/Programmi/Quantum: c:/Programmi/Quantum: No such file or directory
> He uses a path with space:
> c:/Programmi/Quantum GIS/
> Is that a GRASS problem? Where to fix? To me it looks like
OK I've looked into this a bit more and it seems there is indeed a problem
but I don't think it's GRASS. More to do with the way the Msys shell
interprets the path to the script passed to it by the Windows _spawnlp()
function. It reminds me strongly of what Glynn was saying about the
difference between a list of strings, and one string with spaces used as
separators: http://grass.itc.it/pipermail/grass-dev/2007-May/031394.html
I wonder if something like that is going on with the way the Msys shell is
interpreting its command-line arguments, or with the way Windows is
passing them to it. As proof of concept, the patch below seems to make it
work, but putting quotes in when they shouldn't be needed is very ugly and
might break it for non-Msys shells so I don't want to fix that.
Paul
Index: general/g.parser/main.c
RCS file: /home/grass/grassrepository/grass6/general/g.parser/main.c,v
retrieving revision 2.15
diff -u -r2.15 main.c
--- main.c      8 Mar 2007 17:42:51 -0000       2.15
+++ main.c      4 Jun 2007 15:45:52 -0000
@@ -412,10 +412,13 @@
         /* _spawnlp ( _P_OVERLAY, "sh", "sh", filename, "@ARGS_PARSED@", NULL ); */
         int ret;
         char *shell = getenv("GRASS_SH");
+       char *quotedfile;
+       G_asprintf(&quotedfile, "\"%s\"", filename);
         if( shell == NULL )
             shell = "sh";
-       ret = _spawnlp ( _P_WAIT, shell, shell, filename, "@ARGS_PARSED@", NULL);
+       ret = _spawnlp ( _P_WAIT, shell, shell, quotedfile, "@ARGS_PARSED@", NULL );
         G_debug ( 1, "ret = %d", ret );
         if ( ret == -1 )
