[GRASS-dev] inverted color scales
Thu Jun 28 06:44:51 EDT 2007
Maciej Sieczka wrote:
> > What do you guys think of a flag in r.colors to apply an _inverted_ color
> > scale?
> Sounds really usefull to me.
Sounds really trivial to implement, too.
"struct Colors" already has an "invert" field, which can be inverted
with G_invert_colors().
AFAICT, you just need e.g.:
    flag.n = G_define_flag();
    flag.n->key = 'n';
    flag.n->description = _("Invert colors");
    if (flag.n->answer)
	colors = colors_tmp;
The only issue is whether the inversion should come before or after
logarithmic scaling (I think that it matters, although I haven't
actually checked).
As more transforms are added, it's looking more important to replace
the various flags with an option, e.g. trans=log,eq,inv.
NOTE: this will add another situation where the GUI's assumption that
opt->multiple=YES implies a set (rather than a list) will fail.
