[GRASS-dev] Re: gis.m, thematic layer: You must open a display monitor
Maris Nartiss maris.gis at gmail.com
Fri Mar 2 04:42:15 EST 2007
Sorry, copy-paste introduced typo by me. Attached patch should fix
problem. Please, test and commit.
Maris.
2007/3/2, Moritz Lennert <mlennert at club.worldonline.be>:
> On 02/03/07 08:59, Daniel Calvelo wrote:
> > Sorry for the awful delay. I think the problems with d.mon select are
> > resolved; please test. I also made the legend cuts work for ps.map and
> > display managers. In CVS.
> I get the following error. The line
> format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)
> seems to be the problem.
> Moritz
> expected integer but got "1,"
>      while executing
> "format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)"
>      (procedure "GmThematic::tlegend" line 11)
>      invoked from within
> "GmThematic::tlegend $mon $id"
>      (procedure "GmThematic::display" line 72)
>      invoked from within
> "GmThematic::display $node $mod"
>      ("thematic" arm line 2)
>      invoked from within
> "switch $type {
>          group {
>              GmGroup::display $node $mod
> 		raster {
> 			GmRaster::display $node $mod
> 		labels {
> 			GmLabels::disp..."
>      (procedure "GmTree::display_node" line 7)
>      invoked from within
> "GmTree::display_node $n $mod"
>      (procedure "GmGroup::display" line 22)
>      invoked from within
> "GmGroup::display "root" $mod"
>      (procedure "MapCanvas::runprograms" line 64)
>      invoked from within
> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
>      (procedure "MapCanvas::drawmap" line 38)
>      invoked from within
> "MapCanvas::drawmap $mon"
>      (procedure "MapCanvas::display_server" line 9)
>      invoked from within
>      ("after" script)
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070302/ffa23fee/thematic.typo.bin
