[GRASS-dev] grass location creation
Thu Mar 8 00:40:33 EST 2007
Jachym Cepicky wrote:
> patch for g.region is part of this email
> however, it does not work :-( I took the code from r.in.gdal (main.c
> arround lines 526-546), everything looks good.. but it does not work
> +        if (flag.savedefault->answer) {
> +            char *location = G_location_path();
> +            char *path = (char *) G_malloc(sizeof(location)+64);
> +            strcpy(path,location);
> +            strcat(path,"/PERMANENT/");
> +            G__put_window( &window, path, "DEFAULT_WIND" );
The second argument to G__put_window has to be an "element", i.e. a
directory in the current mapset. r.in.gdal uses "../PERMANENT", which
works because the element is simply concatenated onto the path to the
mapset directory.
I suggest that you adopt the same approach, i.e.:
	G__put_window( &window, "../PERMANENT", "DEFAULT_WIND" );
