[GRASS-dev] grass location creation
Fri Mar 9 07:37:47 EST 2007
Jachym Cepicky wrote:
> general/g.region/cmd/main.c:
> 851         if (flag.savedefault->answer)
> 852             if (strcmp(G_mapset(),"PERMANENT") == 0)
> 853                 G__put_window( &window, "../PERMANENT", "DEFAULT_WIND" );
> 854             else
> 855                 G_warning(_("You are not in mapset PERMANENT, default region    -> remains untached"));
> is it sufficient?
  853                 G__put_window( &window, "", "DEFAULT_WIND" );
If you're already in PERMANENT, there's no need for "../PERMANENT".
Otherwise, fine.
