[GRASS-dev] latlong problem
Martin Landa landa.martin at gmail.com
Fri Mar 9 10:10:53 EST 2007
2007/3/9, Martin Landa <landa.martin at gmail.com>:
[snip]
> > With those two changes, Antarctica rendered correctly. Hopefully,
> > that's likely to be good enough for most practical purposes.
> Great!, with render=c seems to work.
just note, I tried to add new vertex
 v.edit map=cs tool=break coords=0,-89.999
and default render methods works also. Not important, just following
your notes;-)
Martin
> Thanks...
> Martin
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
