[GRASS-dev] d.rast.edit replacement candidate
Mon Mar 12 17:03:07 EDT 2007
Paul Kelly wrote:
> I tried running it on Windows - looks neat enough. A few comments:
> Couldn't get it running directly: as far as I can see the
> exec "$GRASS_WISH" "$0" "$@" syntax is having problems with confused
> Msys/Windows paths or something. Hard to get to the bottom of.
Hmm. I could add a front-end shell script which does the g.parser
stuff then explicitly invokes $GRASS_WISH on the Tcl script.
> But running g.parser directly on the script file works OK. I came across
> the problem with r.out.ppm always returning an error code but I see you've
> already fixed that in CVS. Does that mean nobody had ever tried running
> it from Tcl before?
I presume so.
> The 2>@stderr syntax doesn't work on Windows and when I changed it to
> 2>NUL: everything ran OK.
> Noticed a bug: can only save the output map once - the second and
> subsequent times I get a broken pipe error - caused by error message from
> r.in.ascii about over-writing the file - possibly call it with --overwrite
> option? I guess if there was a pre-existing map it will have been checked
> at the time the script was started, so d.rast.edit will only be
> over-writing what it itself created.
I originally figured that if you run the d.rast.edit script with --o,
it would set GRASS_OVERWRITE, and if you didn't use --o, you would
want overwrite to fail. I didn't allow for saving it twice.
I'll change it to explicitly use --o when calling r.in.ascii.
> Also it would be good if there was some way it could determine if the
> region was too large and abandon startup instead of using up lots of
> memory and taking a long time to do nothing. Maybe you could calculate
> something from the width of the black lines between the cells and the size
> of the canvas in pixels, and determine when there would be so many cells
> that the lines between them would merge together, and refuse to run then?
> I suppose you would need to provide an option then for people with huge
> monitors and high-spec PCs - maybe it could read the initial screen size
> from the environment variables for the monitor size or something.
The cells will never be any smaller than 12x12; it will enlarge the
view if necessary (hence the scrollbars). However, it might take a
long time to start up if you have a lot of cells.
FWIW, spearfish at 100m resolution (190x143 = 27170 cells) takes 7
seconds to start up on a P3/800. I would expect it to take over a
minute at the default 30m resolution (634x477 = 302418 cells).
Obviously, using it on high-resolution data isn't going to be
practical.
Choosing a "sane" limit is hard, given the range of hardware.
Ultimately, the user can always kill it with Ctrl-C if it takes too
long. It might be worth adding a progress bar to give the user some
advance warning.
> Also: title bar currently says d.rast, not d.rast.edit.
Presumably, the Windows Tcl/Tk treats ".edit" as the executable's
extension and omits it as it would ".exe".
I'll add a "wm title ...".
I'll also replace the hard-coded canvas width/height and cell size
with options.
