[GRASS-dev] Re: [GRASS-user] Compiling grass 6.2.1: i.class error
Brad Douglas rez at touchofmadness.com
Tue Mar 13 23:47:28 EDT 2007
On Wed, 2007-03-14 at 15:29 +1300, Hamish wrote:
> Glynn Clements wrote:
> > Every other --without-* switch should work without requiring
> > additional effort from the user, but curses is currently sufficiently
> > ingrained that making --without-curses work nicely is too much effort
> > for a relatively obscure usage case.
> ./configure --help
>   --with-glw              support GLw functionality (default: no)
>   --with-glw-includes=DIRS
>                           GLw include files are in DIRS
>   --with-glw-libs=DIRS    GLw library files are in DIRS
> Is GLw still relevant? If not, let's remove it.
Can we add --with-motif* to the list?  And --with-readline* for good
measure?
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
