[GRASS-dev] make install fails with 6.3 CVS
Wed Mar 14 07:36:41 EDT 2007
Maciej Sieczka wrote:
> Current 6.3 CVS builds fine, but on make install a bunch of:
> tar: path/to/file: file changed as we read it
> is issued (full log of make install is attached).
> Also some strange 'NONE' subdir is created in the source dir.
I can't reproduce either of these symptoms.
