[GRASS-dev] Re: [GRASS-user] Compiling grass 6.2.1: i.class error
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Mar 14 17:29:00 EDT 2007
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
On Mar 14, 2007, at 4:01 PM, Brad Douglas wrote:
> On Wed, 2007-03-14 at 12:11 +0000, Glynn Clements wrote:
>> Brad Douglas wrote:
>>>>> Every other --without-* switch should work without requiring
>>>>> additional effort from the user, but curses is currently
>>>>> sufficiently
>>>>> ingrained that making --without-curses work nicely is too much
>>>>> effort
>>>>> for a relatively obscure usage case.
>>>> ./configure --help
>>>>   --with-glw              support GLw functionality (default: no)
>>>>   --with-glw-includes=DIRS
>>>>                           GLw include files are in DIRS
>>>>   --with-glw-libs=DIRS    GLw library files are in DIRS
>>>> Is GLw still relevant? If not, let's remove it.
>>> Can we add --with-motif* to the list?
>> It's used by xganim, which is still compiled if you use --with-motif.
> I was under the impression that xganim would be going away.
PLEASE, PLEASE do not remove xganim before there is an equaly
easy to use, fast replacement. I don't know about any other other tool
for visually analyzing outputs of dynamic models (easily 20-50 rasters),
especially when you are looking for a problem in data or algorithm.
Same for r.digit - it provides a simple and fast tool to create for
example
  raster mask and similar tasks - that is much simpler than doing
v.digit and v.to.rast.
We have already removed site format making some tasks that were
easy to do much more difficult or even impossible, without making sure
that the new vector format offers the same capabilities so
let us not repeat the same mistake,
Helena
>>> And --with-readline* for good measure?
>> Why? Some people seem to want that functionality in r.mapcalc.
> I don't recall any significant replies when you asked about it awhile
> ago other than me mentioning that I have used it before (but was not
> necessary).  I could be wrong.
> Brad Douglas <rez touchofmadness com>                    KB8UYR/6
> Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
