[GRASS-dev] string madness
Sun Mar 18 08:29:11 EDT 2007
Markus Neteler wrote:
> > This patch is entirely inappropriate. You're adding a hack to fix a
> > specific broken table.
> Accepted that my fix is broken, but the table isn't:
Yeah, I noticed that afterwards. I had assumed that litetype was the
actual type reported by SQLite (sqlite3_column_type). Then I
discovered that it was being synthesised by affinity_type().
