[GRASS-dev] [grass-code R][338] different sampling methods
grass-coder at wald.intevation.org grass-coder at wald.intevation.org
Mon Mar 19 11:00:07 EDT 2007
code R item #338, was opened at 2007-03-19 15:00
Status: Open
Priority: 3
Submitted By: Martin Wegmann (wegmann)
Assigned to: Nobody (None)
Summary: different sampling methods
Issue status: None
GRASS component: vector
Operating system: Linux
Operating system version: debian
Initial Comment:
Hello,
beside v.random or r.random to set points for latter analysis into an area other options would be very handy:
- sampling every 10th point of raster
- linear sampling: small areas have less points than larger areas
other sampling strategies could be implemented see Dylans page: http://casoilresource.lawr.ucdavis.edu/drupal/node/320
this ought to be either done per raster or per raster but separated by classes in raster.
Martin
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=338&group_id=21
