[GRASS-dev] Update of r.surf.idw to FP
Tue Mar 20 14:24:09 EDT 2007
Markus Neteler wrote:
> I have tried to update r.surf.idw to floating point:
> http://mpa.itc.it/markus/tmp/rsurfidw.diff
> but I am not quite sure if this is efficient like this.
> Currently it doesn't compile due to some "extern" magic
> which I don't quite understand.
> I have been inspired by r.example.
The problem is that you have renamed some (but not all) occurrences of
"cell" to "outrast", although the variable is still called "cell".
