[GRASS-dev] Update of r.surf.idw to FP
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Mar 20 16:51:42 EDT 2007
On Tue, 20 Mar 2007, Markus Neteler wrote:
>>> I have tried to update r.surf.idw to floating point:
>>> http://mpa.itc.it/markus/tmp/rsurfidw.diff
>>> but I am not quite sure if this is efficient like this.
>>> Currently it doesn't compile due to some "extern" magic
>>> which I don't quite understand.
>>> I have been inspired by r.example.
>> The problem is that you have renamed some (but not all) occurrences of
>> "cell" to "outrast", although the variable is still called "cell".
> I see.
> Thinking about it again: probably it is a waste of time.
> Proposal:
> - write a script to emulate r.surf.idw[2], calling
>   - r.to.vect
>   - v.surf.idw
> - retire r.surf.idw and r.surf.idw2, substitute them by this script.
> Since both r.surf.idw and r.surf.idw2 are half broken (r.surf.idw2 more
> than the other) and v.surf.idw works, this might be the least cost path
> for maintenance.
>From reading the manpage, it looks like r.surf.idw has some features that
aren't present in v.surf.idw. E.g. correct calculation of distances in
lat/long locations, error output. However r.surf.idw2 doesn't look very
useful. It seems that the functionality of r.surf.idw2 would be better
kept as a command-line option for r.surf.idw. Perhaps the author of
r.surf.idw had in mind that this improved version would replace
r.surf.idw2, but the GRASS developers at the time were hesitant and kept
it on in case anybody needed it?
Paul
