[GRASS-dev] d.menu, d.ask
Fri Mar 23 19:45:34 EDT 2007
Glynn Clements wrote:
> I've modified d.rast.edit to use two windows. The first displays the
> entire map, overlaid with a rectangle showing the region to be edited,
> while the second is the editing window.
> I'd like comments as to whether this is ready to replace the existing
> d.rast.edit. Currently, both are built, with the Tcl/Tk version going
> into $GISBASE/scripts and the C version in $GISBASE/bin. As "bin"
> comes before "scripts" in the path, the C version needs to be removed
> or renamed in order for "d.rast.edit" to invoke the Tcl/Tk version.
As no-one has objected, I've changed display/Makefile so that the
original d.rast.edit is no longer built. Running d.rast.edit will
