[GRASS-dev] discussion: replacing ps.map
Maciej Sieczka tutey at o2.pl
Fri Mar 30 04:36:48 EDT 2007
>> FWIW, I've committed a basic PostScript driver to CVS.
Great!
>> At present, there are doubtless many things which don't work
>> correctly, or are sub-optimal (especially polygon filling, which
>> currently uses the generic software renderer, i.e. lots of horizontal
>> lines).
> I've fixed this; R_polygon_{abs,rel} will get PostScript to do the
> filling. With d.vect, you need to use render={r,d,c} to prevent it
> from using G_plot_polygon().
Different render methods are not explained in d.vect manual. Where can
I read about them?
Maciek
