[GRASS-dev] font path question for Linux and Windows
Wed May 2 04:40:08 EDT 2007
Glynn Clements wrote:
> The updated mkftcap script should cope with multi-font files; the part
> which uses fc-list outputs the index, and should append it to the path
> if it isn't zero. I can't test this, as none of my font files have
> more than one font.
> Also, I haven't updated the driver code to handle indices yet.
I've updated the driver, although I can't actually test it with
multi-font files.
