[GRASS-dev] Streams extraction from streams map
Markus Neteler neteler at itc.it
Wed May 2 11:12:06 EDT 2007
On Wed, May 02, 2007 at 08:05:40AM -0700, Michael Barton wrote:
> Markus,
> I remember that someone recently wrote a module that will calculate stream
> Strahler order. This may well have code that you can use for this task,
> since it must calculate whether or not a stream segment has 'tributaries'. I
> think that it's posted somewhere--WIKI, Grassaddons, ?
I tried this v.strahler recently but it didn't work (it is in the GRASS
Addons SVN) - for me. Maybe it's still under development. But yes,
this would probably do the job.
Markus
