[GRASS-dev] Re: d.vect changes
Markus Neteler neteler at itc.it
Thu May 3 01:47:59 EDT 2007
On Thu, May 03, 2007 at 03:01:46PM +1200, Hamish wrote:
> Markus wrote:
> > d.vect kills x0
> > strace d.vect myroads_net col=red
> don't know, can you reproduce it with a spearfish map?
> make distclean? ;)
It happens with Spearfish. Just try my new v.net.path
example in the description.html.
BTW: the v.clean step therein fails - it does NOT properly
connect the lines. Sigh.
Markus
