[GRASS-dev] CVS branch problem
Markus Neteler neteler at itc.it
Wed May 16 10:29:54 EDT 2007
I wanted to backport the v.dissolve column support to the
6.2 release branch, but
bartok:v.dissolve[3553.44] cvs ci -m"backported col support"
cvs commit: Examining .
cvs server: sticky tag `releasebranch_6_2' for file `description.html' is not a branch
cvs server: sticky tag `releasebranch_6_2' for file `v.dissolve' is not a branch
cvs [server aborted]: correct above errors first!
>From  http://owen.sj.ca.us/rkowen/howto/cvs.html I got that
the tag isn't on the branch (or so) and I tried:
bartok:v.dissolve[3554.45] cvs tag -b -r releasebranch_6_2 releasebranch_6_2
cvs server: Tagging .
W Makefile : releasebranch_6_2 already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2
W description.html : releasebranch_6_2 already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2
W v.dissolve : releasebranch_6_2 already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2
but the problem persists. Suggestions welcome. AFAIR the v.dissolve
was added later to the branch (and hence the mess).
Markus
