[GRASS-dev] Re: [GRASSGUI] Re: [grass-addons] r659 - trunk/grassaddons/gui/gui_modules
Michael Barton michael.barton at asu.edu
Wed May 16 14:21:53 EDT 2007
The good thing about using the command class is that if we get it right
THERE, then it will be right throughout the GUI, and we won't have to change
each instance that we call a GRASS command.
This was the gist of my post. Martin is doing the cmd.py module and can fix
it so that it doesn't use SHELL.
Michael
On 5/16/07 10:15 AM, "Martin Landa" <landa.martin at gmail.com> wrote:
> Glynn,
> 2007/5/16, Glynn Clements <glynn at gclements.plus.com>:
>>> Are you thinking that we should change all calls to GRASS commands to use
>>> the new cmd module?
>>>> +        cmdString = "g.region -ugp region=%s" % wind
>>>> +        p = cmd.Command (cmdString)
>> This interface is broken, and needs to be replaced.
>>            self.module = subprocess.Popen(self.cmd, shell=True,
>> Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong.
>> Just how clearly do I have to say this before it sinks in:
>>         DO NOT USE THE SHELL
>> Using the shell means problems with spaces, quotes and other shell
>> metacharacters. There is no reason to use it. So don't.
> OK, then we need to fix Command class... (I will look at it tomorrow)
> Martin
>> grassgui mailing list
>> grassgui at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassgui
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
