[GRASS-dev] g.mapsets use of sleep()
Markus Neteler neteler at itc.it
Wed May 16 16:58:18 EDT 2007
[ MinGW compile errors for sleep() ]
Glynn Clements wrote:
> ... use G_sleep() instead:
>>From lib/gis/sleep.c:
> 	unsigned int G_sleep (unsigned int seconds)
> 	#ifdef __MINGW32__
> 	    /* TODO: no sleep for now */
> 	    return 0;
> 	#else /* __MINGW32__ */
> 	    return sleep(seconds);
> 	#endif /* __MINGW32__ */
> On MinGW, it doesn't actually sleep, but at least you don't get a link
> error.
I have added there code for MinGW to use Sleep() and updated
all remaining sleep() to G_sleep().
Markus
View this message in context: http://www.nabble.com/g.mapsets-use-of-sleep%28%29-tf2764621.html#a10654453
Sent from the Grass - Dev mailing list archive at Nabble.com.
