[GRASS-dev] Background Colours
Michael Barton michael.barton at asu.edu
Thu May 17 11:35:48 EDT 2007
This is all nice. But I'm a bit confused at the moment as to what color
options are built into d.histogram and which require setting environmental
variables. I'll try to recompile today and try it out.
If there is a bg color setting built into the module now, this is a breeze
to set in the GUI--especially since it looks like the bg option will accept
rrr:ggg:bbb colors. The complications of transparency I mentioned in the
last post can simply be ignored with the assumption that we won't be showing
a histogram with anything other than a solid color background from the GUI.
Especially for wxpython, where a histogram shows up in a separate window,
transparency is irrelevant in this particular case.
Michael
On 5/17/07 2:04 AM, "Paul Kelly" <paul-grass at stjohnspoint.co.uk> wrote:
> On Thu, 17 May 2007, Hamish wrote:
>> I would prefer to add a background color option to d.histogram, with a
>> default of DEFAULT_BG_COLOR and an option of "none".
> So using the "none" option means the transparency settings are respected?
> I suppose that's enough then, as long as that functionality is there. I
> was just thinking of some possible application where you might want to
> display the histogram transparently in some kind of widget box and you
> didn't know in advance what colour it would be, so need it transparent.
> Paul
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
