[GRASS-dev] Problems with wish
Juan Diego Giraldo Osorio Juan.Giraldo at upct.es
Wed May 30 07:44:34 EDT 2007
Agustin
I started grass with
[jdgiraldo at labitf08 ~]$ grass62
and the prompt shows
GRASS 6.2.1 (SENEGAL):~ >
I'm working in a Mapset called SENEGAL.
>From here I access to r.example's directory:
GRASS 6.2.1 (SENEGAL):~ > cd grass-6.2.1/dist.x86_64-unknown-linux-gnu/bin
GRASS 6.2.1 (SENEGAL):~/grass-6.2.1/dist.x86_64-unknown-linux-gnu/bin >
and here I try to execute r.example:
./r.example
sh: wish: command not found
"ERROR"
Again, I think that grass doesn't call the suitable command (wish8.4
instead wish) but I don't know how (or where) redir the code.
Thanks
Juan
> Juan,
> You need to start grass before, something like ./grass.sh or simply
> grass6, and once grass is started , you will see the following
> GRASS 6.3.cvs (Projecte):/your path/ >
> There is where you need to put r.example
> Best
> n May 30, 2007, at 1:06 PM, Juan Diego Giraldo Osorio wrote:
> > Hi coworkers
> > Now I have compiledand installed the grass-6.2.1 package with the
> > following instruction:
> > ./configure --with-postgres-includes=/usr/local/pgsql/include
> > --with-postgres-libs=/usr/local/pgsql/lib --enable-64bit
> > --with-libs=/usr/lib64
> > the procedure don't show problems. However, when I try to execute
> > ./r.example in /dist.x86_64-unknown-linux-gnu/bin the prompt shows:
> > I have tcl8.4 and tk8.4. when I execute "wish8.4" tk runs without
> > problems. I think that the problem is the grass isn't executing the
> > correct command, but I don'k know how to redir to wish8.4 instead
> > wish.
> > Thanks
> > Juan
> >> On Wed, May 30, 2007 at 05:39:19AM +0100, Glynn Clements wrote:
> >>> Markus Neteler wrote:
> >>>> you have to run GRASS commands *inside* GRASS, means, that
> >>>> you have to launch GRASS first. Then all paths will be
> >>>> defined.
> >>> To start the version of GRASS which has just been compiled, without
> >>> having to install it, run "bin.i486-pc-linux-gnu/grass62".
> >> Hi Juan,
> >> once you have it all working for you - please let us know where
> >> and how to better document it!
> >> Markus
> >> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
> >> ITC -> since 1 March 2007 Fondazione Bruno Kessler
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
