[GRASS-dev] psdriver docs drafted
Thu May 31 05:31:47 EDT 2007
Markus Neteler wrote:
> I still wonder how to define the resolution (DPI).
> Example: for the GRASS book I would like to generate
> screenshots and such as PDFs at reasonable resolution.
> d.out.file gives me resolution control as multiplier
> to the GRASS monitor size. Are there other tricks?
the multiplier in d.out.file is only useful for defining the bounding
box size of .eps output. That is why it (and size=) are in the Images
tab, not the general options tab- with .ps output they are not used.
a0-a4 are all perfectly proportional, you might "print" bigger then
scale down?
I think for book screenshots the PNG driver is still your best bet.
(e.g. nicest fonts, no 0-width line problems like PS driver, etc)
Hamish
