[GRASS-dev] select issue with wingrass
Tue Nov 6 10:53:47 EST 2007
Michael Barton wrote:
> I agree that it certainly looks like the problem code is
> glob -nocomplain $path/*
> "glob" ought to work because it is pure TclTk in this case (although
> identical to the unix command). What about the "*"?
> I don't know how to test this on Windows. Suggestions?
Run tclsh in a console, and type e.g.:
	glob -nocomplain C:/*
