[GRASS-dev] select issue with wingrass
Mon Nov 19 11:09:49 EST 2007
Michael Barton wrote:
> Given other discussions about forward and backward slashes, should
> env(GISDBASE) be run through file normalize or not? What about env(GISBASE)?
Ideally, it shouldn't be necessary; they should be in "internal"
format already. But it won't do any harm.
Code which passes filenames to the OS' shell needs to explicitly call
G_convert_dirseps_to_host() (C) or "file nativename ..." (Tcl).
