[GRASS-dev] Pipeline efficiency in bash shell scripts
Wed Oct 10 14:26:32 EDT 2007
Patton, Eric wrote:
> I'll keep this short and provide more details if people need it. In a
> for loop within bash scripts, where several commands are performing
> text manipulation, is it more efficient to pipe the commands together
> in one long pipeline (case 1), or instead dump the output from one
> program into a text file and use a redirection to input the results
> into a second command (case 2)?
> Case 1
> for FILES in *.extension ; do
>     mbnavlist -Iinputfile -OJXY -N0 | awk '{lots of awk text manipulation goes here}' | v.in.ascii
> done
> Case 2
>     mbnavlist -Iinputfile -OJXY -N0 > TMP.txt
>     awk '{slicing and dicing commands go here}' < TMP.txt > v.in.ascii
> OR
>     awk '{slicing and dicing commands go here}' < TMP.txt > TMP2.txt
> follwed by
>     v.in.ascii < TMP2.txt
> In both cases, the for loop is calling the mbnavlist program (from
> free and open source bathymetry processing software MBTools) and awk
> together thousands or times. I wasn't sure if there are any general
> benefits to piping vs. writing out to a file, then redirecting input.
> Any suggestions?
Any difference is likely to be so small that there's no reason to
prefer one to the other based upon efficiency concerns.
Exactly which will be more efficient depends upon more factors than
can reasonably be discussed here.
