[GRASS-dev] OSX FFMPEG build instructions available
Mon Oct 22 14:54:17 EDT 2007
William Kyngesburye wrote:
> I finally got back to FFMPEG on OSX.  It went fairly smooth this
> time.  I added build instructions to the GRASS OSX readme.  My future
> OSX builds will now have ffmpeg support, yay!
> Question: what is the minimum needed in the ffmpeg libraries for
> GRASS?  I'm thinking of disabling codecs and formats that GRASS can't
> use to reduce the library size (a basic universal build without debug
> symbols added ~6.5MB to libgrass_ogsf!).  Or can GRASS use any codec
> available in ffmpeg?
It only uses MPEG-1. There's a compile-time option to use XviD, but
that gives you a "raw" XviD stream (no AVI etc container), which isn't
much use.
