[GRASS-dev] Re: [grass-code I][478] tcl/tk gui startup screen launches grass even when 'Exit' is pushed
Moritz Lennert mlennert at club.worldonline.be
Wed Oct 24 07:27:45 EDT 2007
On 24/09/07 19:55, grass-dev at grass.itc.it wrote:
> code I item #478, was opened at 2007-09-07 15:40
>> Status: Open
> Priority: 3
> Submitted By: Moritz Lennert (moritz)
> Assigned to: Māris Nartišs (marisn)
> Summary: tcl/tk gui startup screen launches grass even when 'Exit' is pushed
> Issue type: other bug
>> Issue status: confirmed
> GRASS version: CVS HEAD
> GRASS component: startup
> Operating system: Linux
> Operating system version:
> GRASS CVS checkout date, if applies (YYMMDD): 070903
>> Comment By: Maciej Sieczka (msieczka)
> Date: 2007-09-24 19:55
> Message:
> The issue is more complicated. According to Paul Kelly the committed fix is not complete. See Details Below:
Where are we at with this issue ? At this point it is still not solved
for wingrass and for other platforms I don't know if the solution
currently in CVS for init.sh is deemed satisfactory.
Moritz
> Paul Kelly wrote on GRASS dev ML:
>> I think it's a good idea to change the behaviour here,
>> but I feel the patch doesn't really address the problem:
>> rather it adds more code to work around it. In
>> particular, clicking exit in the gis_set.tcl Window won't
>> work with init.bat (Windows) now, as it used the exit
>> code of 1 to indicate exit (whereas the patch makes an
>> exit code of 2 now indicate exit). I notice also the
>> patch makes the exit code of the Python version of
>> gis_set.tcl be interpreted differently - has anybody
>> checked what effect this will have?
>> The problem is the historical behaviour that an error in
>> gis_set.tcl (e.g. the wrong version of Tcl/Tk) caused it
>> to drop out from attempting the GUI startup but go ahead
>> and start an interactive GRASS shell. When I made a few
>> changes to the return codes from gis_set.tcl I
>> deliberately avoided tackling this because I wasn't sure
>> what was the best solution. But on thinking about it
>> more, I think dropping to an interactive shell is the
>> wrong approach. It should print a warning/error message
>> and then exit, and if the user wants to start in
>> text-based mode instead they can use the -text switch
>> next time round.
>> init.bat assumes a return code of 1 means exit. I vaguely
>> intended the same interpretation for Init.sh, and to
>> remove the facility to drop to an interactive shell when
>> there was an error in gis_set.tcl, but I didn't implement
>> this nor tell anybody about my plans: my fault ;)
>> I think it would simplify things if we made Init.sh
>> always exit when a non-zero exit code is returned from
>> gis_set.tcl- any other thoughts? (I should probably
>> update init.bat too so it goes ahead when 0 is returned,
>> rather than exiting when 1 is returned).
> You can respond by visiting:
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=478&group_id=21
