[GRASS-dev] another not quiet GRASS command
Mon Sep 3 10:22:49 EDT 2007
Hamish wrote:
> In the above case of georect.tcl, we may ask 1) if switching between
> mapsets in the script is really the best solution; 2) if that warning
> should be a warning.
3) If g.mapset is the right way to switch mapsets, or whether gis.m
should generate a temporary GISRC and "set env(GISRC) $tmp_gisrc".
If you're going to modify the existing $GISRC with g.mapset, the user
had better not be running GRASS commands on the terminal in the
meantime.
