[GRASS-dev] Re: Gm::errmsg not defined in lib/gtcltk/gronsole.tcl
Michael Barton michael.barton at asu.edu
Fri Sep 7 01:16:56 EDT 2007
I took out this error reporting message box. It is not needed and clearly
causes occasional problems.
Michael
On 9/6/07 10:01 PM, "Markus Neteler" <neteler at itc.it> wrote:
> Michael,
> since I didn't see a change I guess so that it remains.
> If you run a command (v.info somemap) and then, in the output
> window click on the grey across (like rotated x) then
> you should get the tcl error.
> Markus
> On Thu, Sep 06, 2007 at 09:59:01PM -0700, Michael Barton wrote:
>> Markus,
>> Is this still a problem? I don't source gm.tcl in gronsole.tcl because
>> gronsole.tcl is called by gm.tcl. So there should be no need to source
>> gm.tcl.
>> I'm running this now in x11 with no problem at all. Gm::errmsg is only being
>> called in 2 places, neither critical I think. If this is a general problem,
>> I can just take it out.
>> Michael
>> On 9/6/07 5:34 AM, "Markus Neteler" <neteler at itc.it> wrote:
>>> Michael,
>>> I am currently getting errors due to Gm::errmsg not defined in
>>> (but used). Including
>>> source $env(GISBASE)/etc/gm/gm.tcl
>>> leads to an infinite loop... Maybe Gm::errmsg definition needs
>>> to go into a different file?
>>> Markus
>>> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
>>> ITC -> since 1 March 2007 Fondazione Bruno Kessler
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> Director of Graduate Studies
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
