[GRASS-dev] new std options for files
Martin Landa landa.martin at gmail.com
Fri Sep 7 08:18:50 EDT 2007
you are not only one confused Markus by this;-)
The label/description stuff is a bit illogical. I suppose to change in this way:
* Use 'description' as short sentence describing module/flag/option
(must be defined).
* Rename 'label' to 'tooltip'.
Martin
2007/9/7, Markus Neteler <neteler at itc.it>:
> HamishB wrote:
> >> Hamish wrote:
> >> > as earlier mentioned* I'd like to change the Option struct to
> >> > rationalize the ->description and ->label parts.
> >> > currently, if a label is defined it becomes the description, and the
> >> > description becomes the tooltip. This is non-intuitive and
> >> > inconsistent.
> > so we have three possible levels of verbosity for an option description:
> >   ->label:       a few words
> >   ->description: a sentence
> >   ->tooltip:     a paragraph/short example showing format (doesn't exist)
> > I think it is a good idea to keep ->description (as commonly used now)
> > short and to the point, ie shorter than ~65 chars (so it fits on one
> > line). Certainly the label should quite short. It looks bad when the
> > description is line wrapped in --help, or colliding with the right side
> > of the GUI window.
> I would like to bring up this issue again (since I am confused):
> Currently only about 10 modules use
> module->label
> In the GUI pop up it is even printed in the wrong vertical order
> if above definition is true + there is ugly vertical space between
> these two lines.
> Question: what's the point of module->label? Take it out or
> modify 290+ modules? We need some consistency...
> Is there anything using module->label|description as tooltip?
> confused (about why we need two things to do nearly the same),
> Markus
> View this message in context: http://www.nabble.com/new-std-options-for-files-tf3438602.html#a12554008
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
