[GRASS-dev] [grass-code I][481] v.db.connect -p always reports for layer 1 only
grass-dev at grass.itc.it grass-dev at grass.itc.it
Sun Sep 9 10:02:34 EDT 2007
code I item #481, was opened at 2007-09-09 16:02
Status: Open
Priority: 3
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Nobody (None)
Summary: v.db.connect -p always reports for layer 1 only
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 070909
Initial Comment:
v.db.connect -p always reports for layer 1 only. Even if I specify layer=2, it still talks about layer 1:
Vector map <pts> is connected by:
layer <1> table <pts> in database </home/grassdata/za/PERMANENT/dbf/> through driver <dbf> with key <cat>
Same happens in current 6.2 CVS.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=481&group_id=21
