[GRASS-dev] native WinGRASS and attribute data deadlock, next try
Moritz Lennert mlennert at club.worldonline.be
Sun Sep 16 11:26:55 EDT 2007
Hello,
I have tried to get some more debug output for the wingrass db deadlock
problem. I started from Benjamin's work, and tried to apply Glynn's
suggestions. I have to admit, though, that I still do not completely
understand xdr, so I'm not sure if what I did makes sense.
In order to not have different debug outputs mingle, I had to create 8 log
files, one for each function and for each stream. See xdr_logs.zip.
I also attached the original xdr_stdio.c and a diff with everything I added.
When I now run our test v.out.ogr line:
GRASS 6.3.cvs (qgis-test):C:\GRASSSRC\grass6\bin.i686-pc-mingw32
>v.out.ogr points type=point dsn=c:\test
I get the message:
Exporting 2898 points/lines...
And then nothing else. The percentage counter never appears.
Please tell me if these logs are in any way helpful and, if not, what I
could do to improve them.
Moritz
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070916/3d9405d7/xdr_logs.zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070916/3d9405d7/xdr_stdio.zip
