[GRASS-dev] g.mlist problem
Michael Barton michael.barton at asu.edu
Tue Sep 18 11:04:06 EDT 2007
William,
I'm very glad you've identified the problem. But I worry whether this
solution is portable across platforms.
Michael
On 9/18/07 6:47 AM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> Same happens for me (OSX).  I walked thru the script commands
> manually, and it is indeed messing up on the first sed.
> I see this in the sed man for Sed Regex info (OSX uses the BSD sed):
> 2.   The escape sequence \n matches a newline character embedded in the
>       pattern space.  You can't, however, use a literal newline
> character
>       in an address or in the substitute command.
> Later, for the s/ function, it says:
> A line can be split by substituting a newline character into it.
> To specify a newline character in the replacement string, precede
> it with a backslash.
> Putting a real newline after the \ does the trick:
>      g.list type=$type mapset=$mapset \
> | grep -v '^-\+$' \
> | grep -v "files available" \
> | grep -vi "mapset" \
> | sed 's/  */\
> /g' \
> | grep -v '^$' \
> | grep "$search" \
> | sort \
> | sed -e "s/$/$MAPSET/"
> On Sep 18, 2007, at 2:15 AM, Michael Barton wrote:
>> Wolf,
>> I just checked the 'binary' version against the source version of
>> g.mlist.
>> Both are identical.
>> There must be something problematic in the new code. Has anyone
>> else had
>> this problem?
>> Has this been tried on a Mac? I don't know what difference that
>> would make,
>> but maybe something... I do know there there are some differences
>> in Mac OS
>> X awk and Linux awk. I don't know about sed and bash.
>> Michael
>> On 9/18/07 12:01 AM, "Wolf Bergenheim" <wolf+grass at bergenheim.net>
>> wrote:
>>> On 18.09.2007 09:56, Michael Barton wrote:
>>>> I tried the new fast g.mlist and got very weird results. Running
>>>> g.mlist
>>>> rast returned mapnames like...
>>>> elevation.10mnrstrct.areasn
>>>> ... instead of
>>>> elevation.10m
>>> It seems there is a missing \ before the n somewhere in the code,
>>> since
>>> \ + n => \n = new line. Or then your compiler doesn't handle "\n"
>>> properly.
>>> --Wolf
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
