[GRASS-dev] r.neighbors bug in cvs
Dylan Beaudette dylan.beaudette at gmail.com
Wed Sep 19 17:47:06 EDT 2007
On Wednesday 19 September 2007, Trevor Wiens wrote:
> On Wed, 19 Sep 2007 11:44:52 -0700
> > > On Wed, 19 Sep 2007 09:19:07 +0100
> > > Glynn Clements <glynn at gclements.plus.com> wrote:
> > > > Fixed in CVS, with:
> > > Confirmed. Downloaded and retested this morning. Thanks
> > > T
> > Are there any mechanisms in place such that core modules like this can be
> > tested on a regular basis for correct results ?
> I don't know what would be ideal, but one possiblity would be to start
> building a testing map set for the Spearfish data set and some simple
> scripts to go with it.
> In the case of r.neighbors for example I would think as simple script would
> be ideal. something like
> begin loop through neighbors operations
> 	r.neighbors over limited area
> 	r.what to extract values from specific location
> 	results match
> 		report OK
> 	results don't match
> 		report problem
> end loop
> I would think that if this was slowly built up for each core module, then
> future developers could simply use this as a testing mechanism which should
> speed development.
> Also, prior to release a master script could run each of these in turn
> against the rc versions to make sure that the core functionality was still
> working.
> I realize this is labour intensive but have no suggestions as to a quicker
> but still reliable method.
> For myself, I doubt I will have little time to this, as I still have
> v.buffer waiting to be fixed on my to do list.
> T
Good ideas. It looks like Soren did some work on an excellent testsuite for
GRASS... but not sure how to use / extend it. Perhaps I can spend some time
on this after by thesis is done...
cheers,
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
