[GRASS-dev] Re: [GRASS GIS] #117: r.digit fails if launched from menu
Sat Apr 5 22:06:11 EDT 2008
>   Reporter:  4everskiff  |       Owner:  grass-dev at lists.osgeo.org
>       Type:  defect      |      Status:  new
>   Priority:  major       |   Milestone:  6.3.0
>  Component:  default     |     Version:  6.3.0 RCs
> Resolution:              |    Keywords:
> Comment (by hamish):
>  Hamish:
>  > > r.digit works fine if launched from the WinGRASS command line?!
>  Marco:
>  > Yes, this is WinGRASS (Native Windows Binary) and r.digit works fine if
>  started
>  > from command line
>  You can really digitize then view a map created with it? As far as I knew
>  r.digit needed an interactive xmon window, which is only available if
>  using X11. It should fail with a "no monitor found" error *after* you give
>  it a map name.
Yep. It uses the R_get_location_with_* functions, so it won't work
without an X monitor.
