[GRASS-dev] r.info -r (was: G_exp_colors()?)
    Maciej Sieczka
    tutey at o2.pl
    Wed Apr  9 03:21:58 EDT 2008
Glynn Clements pisze:
> Bear in mind that "r.info -r" is approximating the min/max values to 6
> decimal places. The actual min/max will be much closer to the values
> in the first line of the colr file. IEEE "double" is ~15 significant
> decimal digits.
Could r.info -r print a different number of decimal digits, apropriate
for DOUBLE and FCELL data type, respectively? Eg. 6 (or 7?) for FCELL
and 15 (or 16?) for DCELL.
Maciek
