[GRASS-dev] [GRASS GIS] #138: PNG_driver: boundary at right side is one Pixel off
GRASS GIS trac at osgeo.org
Thu Apr 24 11:48:58 EDT 2008
 Reporter:  schulzea    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  default     |     Version:  unspecified
 Keywords:  PNG_driver  |
 I want to export an image with the PNG driver, but there seems to be a
 problem. Always I get a vertical line with 1 Pixel width.
 I use the following configuration for the export:
 export GRASS_WIDTH=317
 export GRASS_HEIGHT=317
 export GRASS_PNGFILE=$GISDBASE/tester.png
 export GRASS_TRANSPARENT=TRUE
 export GRASS_TRUECOLOR=TRUE
 d.mon start=PNG
 d.rast map=tester
 d.mon stop=PNG
 r.info for this raster shows col=317 and row=317
 When I use r.out.pgn everything is fine. I get an image (317x317) without
 this vertical line. But I need the transparence.
 I use grass 6.2.2 under Ubuntu.
 Is an error of myself or a bug?
Ticket URL: <http://trac.osgeo.org/grass/ticket/138>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
