R: R: [GRASS-dev] Re: WinGRASS-6.3.0 Release Package
Marco Pasetti marco.pasetti at alice.it
Tue Apr 29 15:43:46 EDT 2008
Hi Markus,
On 25/04 at 11.29 I sent you an e-mail with attached the new SVN_Win32.zip,
with the demolocation removed (and also the GPL.TXT from \Estras folder, the
other, and only other, replication in that folder), and with the installer
script modified to reflect those changes. Did you received it? (I check out
the develbranch and, reading the script file uploaded, I noticed that it is
still the old one)
Over that: today I fixed a bug in the installer (with a patch). Read here:
http://trac.osgeo.org/grass/ticket/143#comment:11
What should I do? Upload a new installer (fixed) and update the install
script in the develbranch?
Marco
-----Messaggio originale-----
Da: grass-dev-bounces at lists.osgeo.org
[mailto:grass-dev-bounces at lists.osgeo.org] Per conto di Markus Neteler
Inviato: martedì 29 aprile 2008 21.23
A: GRASS developers list
Oggetto: Re: R: [GRASS-dev] Re: WinGRASS-6.3.0 Release Package
hi Marco,
On Fri, Apr 25, 2008 at 10:54 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Apr 25, 2008 at 10:35 AM, Marco Pasetti <marco.pasetti at alice.it>
wrote:
>  >  2. The SVN_Win32.zip should be extracted to the SVN root.
I have done that now....
>  before expanding, it needs a cleanup: the demolocation is replicated
> which we should avoid:
... taking out the superfluous demo location.
Markus
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
