[GRASS-dev] default icon set in wxGUI
Maciej Sieczka tutey at o2.pl
Tue Aug 12 10:50:29 EDT 2008
Martin Landa pisze:
> Hi,
> 2008/8/12 Maciej Sieczka <tutey at o2.pl>:
>> After installing the current develbranch6 SVN from scratch, wxGUI
>> defaulted to "grass" icon set instead of "silk". The latter is much
>> slicker, looks more proffessional, occupies less space. Could wxGUI
>> default to "silk"?
> a few days ago Michael changed default icon set to the original GRASS.
> I am not sure which icon set should be default, anyway I am using
> silk... Maybe we could vote?
> +1 for silk ;-)
Needless to say me the same: +1 for silk.
The GRASS icon set would require couple of adjustments in the GUI layout
as it's icons are bigger (e.g. in digitizer half of the tools are not
visible unless you manually extend window width).
Maciek
Maciej Sieczka
www.sieczka.org
