[GRASS-dev] testing GRASS 7
Thu Aug 14 00:53:36 EDT 2008
Michael Barton wrote:
> >> So I updated from trunk and compiled GRASS 7 again. Almost everything
> >> compiled fine. When I went to start it, all went well for the startup
> >> screen, but it crashed on loading the wxPython GUI with the following
> >> error: Fatal Python error: Interpreter not initialized (version
> >> mismatch?)
> > IIRC, this means that it's loading a binary module which was compiled
> > for a different version of python, which suggests a PYTHONPATH issue.
> > Or possibly the vdigit module is compiled against the wrong version.
> Hmmm. I think you may have something. v.digit still has not been fixed
> to work on non-Linux platforms, but it is compiling 'without errors'.
Well, v.digit is a mixture of Python code and a dynamic library,
neither of are likely to produce any errors until you actually try to
run them.
