[GRASS-dev] syntax for v.db.update???
Michael Barton michael.barton at asu.edu
Fri Aug 15 14:23:35 EDT 2008
On Aug 15, 2008, at 10:56 AM, Martin Landa wrote:
> Hi,
> 2008/8/15 Michael Barton <michael.barton at asu.edu>:
>> I've tried this all combinations that I can think of and still get
>> an error.
>> So I'm asking the larger community if anyone knows the secret
>> handshake is
>> to get v.db.update to put RGB values into a column for coloring
>> vectors.
>> I would like to get the following to work.
>> v.db.update map=fields layer=1 column=area value=0:128:128
>> where=area>=101
>> and area<=10000
> this should work
> v.db.update map=fields layer=1 column=value value='0:128:128'
> where="area>=101 and area<=10000"
> Martin
Unfortunately not.
GRASS 6.4.svn (Spearfish60_test):~ > v.db.update map=fields layer=1
column=area value='0:128:128' where="area>=101 and area<=10000"
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected $undefined, expecting $end
or ';' processing ':'
in statement:
UPDATE fields SET area=0:128:128 WHERE area>=101 and area<=10000
Error in db_execute_immediate()
ERROR: Error while executing: 'UPDATE fields SET area=0:128:128 WHERE
