[GRASS-dev] Re: [GRASS GIS] #64: ps.map: patch to set customized scalebar units
GRASS GIS trac at osgeo.org
Tue Aug 19 17:20:33 EDT 2008
  Reporter:  alf          |       Owner:  hamish
      Type:  enhancement  |      Status:  assigned
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by neteler):
 I guess you need to revert locally to a pre-indentation version, see
 http://trac.osgeo.org/grass/wiki/HowToSVN#Revertingsubmittedchanges . Then
 apply the patches, then run tools/grass_indent.sh locally and svn update
 back to the current version. The patch here should remain and should be
 easy to extract then.
 Markus
 PS: yes, a pity that it wasn't applied earlier as suggested.
Ticket URL: <http://trac.osgeo.org/grass/ticket/64#comment:4>
