[GRASS-dev] some questions about future development
Tue Aug 19 18:46:13 EDT 2008
Markus Neteler wrote:
> > BTW, a r.external would be a great addition.
> Yes, see:
> http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_5_4/gips/gip-0002.txt
> Still not implemented... next GSoC project?
It's not that much work.
I have attached a "first draft" patch which adds the essential support
to lib/gis. It has only been minimally tested, but seems to work.
To test:
1. Copy a raster map.
2. Export it to an image at its native resolution.
3. Create a cell_misc/<name>/gdal file consisting of two lines: the
filename followed by the band number.
4. Edit the cellhd/<name> file so that "compressed" is 0, and (if it's
a CELL map) "format" is 3.
5. Run "r.support -s <name>" to update the range.
Tomorrow, I'll look into creating an r.external module, adding null
support, etc.
Index: lib/gis/opencell.c
--- lib/gis/opencell.c	(revision 32899)
+++ lib/gis/opencell.c	(working copy)
@@ -159,6 +159,9 @@
     RASTER_MAP_TYPE MAP_TYPE;
     struct Reclass reclass;
     char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+#ifdef GDAL_LINK
+    struct GDAL_link *gdal;
+#endif
     /* make sure window is set    */
     G__init_window();
@@ -252,6 +255,13 @@
 	MAP_NBYTES = CELL_nbytes;
+#ifdef GDAL_LINK
+    gdal = G_get_gdal_link(name, mapset);
+    if (gdal)
+	/* dummy descriptor to reserve the fileinfo slot */
+	fd = open("/dev/null", O_RDONLY);
+    else
+#endif
     /* now actually open file for reading */
     fd = G_open_old(cell_dir, r_name, r_mapset);
     if (fd < 0)
@@ -287,6 +297,11 @@
     if ((fcb->reclass_flag = reclass_flag))
 	G_copy(&fcb->reclass, &reclass, sizeof(reclass));
+#ifdef GDAL_LINK
+    if (gdal)
+	fcb->gdal = gdal;
+    else
+#endif
     /* check for compressed data format, making initial reads if necessary */
     if (G__check_format(fd) < 0) {
 	close(fd);		/* warning issued by check_format() */
Index: lib/gis/G.h
--- lib/gis/G.h	(revision 32899)
+++ lib/gis/G.h	(working copy)
@@ -44,6 +44,9 @@
     unsigned char *null_work_buf;	/* data buffer for reading null rows    */
     int min_null_row;		/* Minimum row null row number in memory */
     struct Quant quant;
+#ifdef GDAL_LINK
+#endif
 struct G__			/*  Structure of library globals */
Index: lib/gis/get_row.c
--- lib/gis/get_row.c	(revision 32899)
+++ lib/gis/get_row.c	(working copy)
@@ -198,12 +198,35 @@
+#ifdef GDAL_LINK
+static int read_data_gdal(int fd, int row, unsigned char *data_buf, int *nbytes)
+    struct fileinfo *fcb = &G__.fileinfo[fd];
+    CPLErr err;
+    *nbytes = fcb->nbytes;
+    err = GDALRasterIO(
+	fcb->gdal->band, GF_Read, 0, row, fcb->cellhd.cols, 1, data_buf,
+	fcb->cellhd.cols, 1, fcb->gdal->type, 0, 0);
+    return err == CE_None ? 0 : -1;
+#endif
 /* Actually read a row of data in */
 static int read_data(int fd, int row, unsigned char *data_buf, int *nbytes)
+#ifdef GDAL_LINK
+    if (fcb->gdal)
+	return read_data_gdal(fd, row, data_buf, nbytes);
+#endif
     if (!fcb->cellhd.compressed)
 	return read_data_uncompressed(fd, row, data_buf, nbytes);
@@ -352,6 +375,36 @@
+static void cell_values_raw(const unsigned char *data,
+			    const COLUMN_MAPPING *cmap, int nbytes,
+			    void *cell, int n)
+    unsigned char *c = cell;
+    const unsigned char *d;
+    COLUMN_MAPPING cmapold = 0;
+    int i;
+    for (i = 0; i < n; i++) {
+	if (!cmap[i]) {
+	    memset(c + i*nbytes, 0, nbytes);
+	    continue;
+	if (cmap[i] == cmapold) {
+	    memcpy(c + i*nbytes, c + (i-1)*nbytes, nbytes);
+	    continue;
+	d = data + (cmap[i] - 1) * nbytes;
+	memcpy(c + i*nbytes, d, nbytes);
+	cmapold = cmap[i];
 /* transfer_to_cell_XY takes bytes from fcb->data, converts these bytes with
    the appropriate procedure (e.g. XDR or byte reordering) into type X
    values which are put into array G__.work_buf.
@@ -370,6 +423,11 @@
     cell_values_int, cell_values_float, cell_values_double};
+#ifdef GDAL_LINK
+    if (fcb->gdal)
+	cell_values_raw(fcb->data, fcb->col_map, fcb->cur_nbytes, cell, G__.window.cols);
+    else
+#endif
     (cell_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
 				       G__.window.cols);
Index: lib/gis/closecell.c
--- lib/gis/closecell.c	(revision 32899)
+++ lib/gis/closecell.c	(working copy)
@@ -133,6 +133,11 @@
        This is obsolete since now the mask_bus is always allocated
+#ifdef GDAL_LINK
+    if (fcb->gdal)
+	G_close_gdal_link(fcb->gdal);
+#endif
     for (i = 0; i < NULL_ROWS_INMEM; i++)
 	G_free(fcb->NULL_ROWS[i]);
     G_free(fcb->null_work_buf);
Index: lib/gis/Makefile
--- lib/gis/Makefile	(revision 32899)
+++ lib/gis/Makefile	(working copy)
@@ -1,7 +1,7 @@
 MODULE_TOPDIR = ../..
 LIB_NAME = $(GIS_LIBNAME)
-EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(INTLLIB) $(MATHLIB)
+EXTRA_LIBS = $(GDALLIBS) $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(INTLLIB) $(MATHLIB)
 DATASRC = ellipse.table datum.table datumtransform.table FIPS.code state27 state83 projections gui.tcl
 include $(MODULE_TOPDIR)/include/Make/Lib.make
@@ -15,6 +15,7 @@
 ifneq ($(USE_LARGEFILES),)
 	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
 endif
+EXTRA_CFLAGS += -DGDAL_LINK
 default: lib $(FMODE_OBJ) $(DATAFILES) $(COLORFILES)
Index: lib/gis/gdal.c
--- lib/gis/gdal.c	(revision 0)
+++ lib/gis/gdal.c	(revision 0)
@@ -0,0 +1,86 @@
+#include <grass/config.h>
+#include <grass/gis.h>
+#include <gdal.h>
+#ifdef GDAL_LINK
+struct GDAL_link *G_get_gdal_link(const char *name, const char *mapset)
+    static int initialized;
+    char filename[GPATH_MAX];
+    char band_str[64];
+    int band_num;
+    GDALDatasetH data;
+    GDALRasterBandH band;
+    GDALDataType type;
+    RASTER_MAP_TYPE map_type;
+    FILE *fp;
+    int err = 0;
+    if (!G_find_cell2(name, mapset))
+	return NULL;
+    map_type = G_raster_map_type(name, mapset);
+    if (map_type < 0)
+	return NULL;
+    fp = G_fopen_old_misc("cell_misc", "gdal", name, mapset);
+    if (!fp)
+	return NULL;
+    if (!G_getl2(filename, sizeof(filename), fp))
+	err = 1;
+    if (!G_getl2(band_str, sizeof(band_str), fp))
+	err = 1;
+    band_num = atoi(band_str);
+    if (!band_num)
+	err = 1;
+    fclose(fp);
+    if (err)
+	return NULL;
+    if (!initialized) {
+	GDALAllRegister();
+	initialized = 1;
+    data = GDALOpen(filename, GA_ReadOnly);
+    if (!data)
+	return NULL;
+    band = GDALGetRasterBand(data, band_num);
+    if (!band) {
+	GDALClose(data);
+	return NULL;
+    switch (map_type) {
+    case CELL_TYPE:	type = GDT_Int32;	break;
+    case FCELL_TYPE:	type = GDT_Float32;	break;
+    case DCELL_TYPE:	type = GDT_Float64;	break;
+    default:		type = GDT_Float64;	break;
+    gdal = G_calloc(1, sizeof(struct GDAL_link));
+    gdal->filename = G_store(filename);
+    gdal->band_num = band_num;
+    gdal->data = data;
+    gdal->band = band;
+    gdal->type = type;
+    return gdal;
+void G_close_gdal_link(struct GDAL_link *gdal)
+    GDALClose(gdal->data);
+    G_free(gdal->filename);
+    G_free(gdal);
+#endif
Index: include/gis.h
--- include/gis.h	(revision 32899)
+++ include/gis.h	(working copy)
@@ -28,6 +28,10 @@
 #include <grass/datetime.h>
+#ifdef GDAL_LINK
+#include <gdal.h>
+#endif
 /*=========================== Constants/Defines ============================*/
 #if !defined __GNUC__ || __GNUC__ < 2
@@ -623,6 +627,17 @@
     int count;
+#ifdef GDAL_LINK
+struct GDAL_link
+    char *filename;
+    int band_num;
+#endif
 /*============================== Prototypes ================================*/
 /* Since there are so many prototypes for the gis library they are stored */
Index: include/gisdefs.h
--- include/gisdefs.h	(revision 32899)
+++ include/gisdefs.h	(working copy)
@@ -521,6 +521,11 @@
 			    int);
 void G_fpreclass_perform_id(const struct FPReclass *, const CELL *, DCELL *,
 			    int);
+/* gdal.c */
+#ifdef GDAL_LINK
+struct GDAL_link *G_get_gdal_link(const char *, const char *);
+void G_close_gdal_link(struct GDAL_link *);
+#endif
 /* geodesic.c */
 int G_begin_geodesic_equation(double, double, double, double);
