r.external - was: Re: [GRASS-dev] some questions about future development
Markus Neteler neteler at osgeo.org
Wed Aug 20 08:13:39 EDT 2008
Glynn,
this is excellent! Thanks so much. I have tested it but no success yet:
On Wed, Aug 20, 2008 at 1:46 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Glynn Clements wrote:
> > > > BTW, a r.external would be a great addition.
>> It's not that much work.
>> Tomorrow, I'll look into creating an r.external module, adding null
>> support, etc.
> Okay, done (well, enough to try it out without having to manually hack
> the files; null support is absent).
[for my convenience I have copied it over to GRASS 6.4.svn locally]
GRASS 6.4.svn (pat):~ > gdalinfo
/geodata2_originals_raid5/pat_OFD_RGB_IT2006_GB/060100.tif
Driver: GTiff/GeoTIFF
Files: /geodata2_originals_raid5/pat_OFD_RGB_IT2006_GB/060100.tif
Size is 13440, 11760
Coordinate System is:
PROJCS["Monte Mario / Italy zone 1",
    GEOGCS["Monte Mario",
        DATUM["Monte_Mario",
            SPHEROID["International 1924",6378388,297.0000000000014,
                AUTHORITY["EPSG","7022"]],
            AUTHORITY["EPSG","6265"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4265"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",9],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",1500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","3003"]]
Origin = (1660920.000000000000000,5107440.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_SOFTWARE=Adobe Photoshop CS2 Macintosh
  TIFFTAG_DATETIME=2007:03:01 06:12:15
  TIFFTAG_XRESOLUTION=72
  TIFFTAG_YRESOLUTION=72
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  ( 1660920.000, 5107440.000) ( 11d 4'54.85"E, 46d 6'2.53"N)
Lower Left  ( 1660920.000, 5101560.000) ( 11d 4'47.69"E, 46d 2'52.14"N)
Upper Right ( 1667640.000, 5107440.000) ( 11d10'7.61"E, 46d 5'56.71"N)
Lower Right ( 1667640.000, 5101560.000) ( 11d10'0.15"E, 46d 2'46.33"N)
Center      ( 1664280.000, 5104500.000) ( 11d 7'27.57"E, 46d 4'24.46"N)
Band 1 Block=13440x1 Type=Byte, ColorInterp=Red
  Overviews: 6720x5880, 3360x2940, 1680x1470, 840x735, 420x368, 210x184
Band 2 Block=13440x1 Type=Byte, ColorInterp=Green
Band 3 Block=13440x1 Type=Byte, ColorInterp=Blue
GRASS 6.4.svn (pat):~ > r.external
out=ortho_trento
Projection of input dataset and current location appear to match
<ortho_trento> created
r.external complete.
GRASS 6.4.svn (pat):~ > g.region rast=ortho_trento -p
projection: 99 (Transverse Mercator)
zone:       0
datum:      rome40
ellipsoid:  international
north:      5107440
south:      5101560
west:       1660920
east:       1667640
nsres:      0.5
ewres:      0.5
rows:       11760
cols:       13440
cells:      158054400
GRASS 6.4.svn (pat):~ > d.rast ortho_trento
WARNING: Error reading map <ortho_trento at PERMANENT>, row 0
 100%
r.info -r ortho_trento
WARNING: category support for [ortho_trento] in mapset [PERMANENT] missing
min=NULL
max=NULL
GRASS 6.4.svn (pat):~ > r.support ortho_trento
Edit header for [ortho_trento]? (y/n) [n]
Update the statistics (histogram, range) for [ortho_trento]? (y/n) [n] y
Updating statistics for [ortho_trento]
WARNING: Histogram for [ortho_trento in PERMANENT] missing (run r.support)
Edit the category file for [ortho_trento]? (y/n) [n]
Create/Update the color table for [ortho_trento]? (y/n) [n]
Edit the history file for [ortho_trento]? (y/n) [n]
The null file for [ortho_trento] may indicate that some cells contain
no data. If the null file for [ortho_trento] doesn't exist, zero cells in
it are treated by GRASS application programs as no data.
Do you want to create/reset the null file for [ortho_trento] so that
null cell values are considered valid data? (y/n) [n]
Do you want to delete the null file for [ortho_trento]
(all zero cells will then be considered no data)? (y/n) [n]
GRASS 6.4.svn (pat):~ > ls -la grassdata/pat/PERMANENT/cell_misc/ortho_trento/
total 86
drwxrwxr-x 2 neteler neteler  1024 2008-08-20 13:49 .
drwx---r-x 8 neteler neteler 84992 2008-08-20 13:49 ..
-rw-rw-r-- 1 neteler neteler    92 2008-08-20 13:49 gdal
-rw-rw-r-- 1 neteler neteler     0 2008-08-20 13:49 range
GRASS 6.4.svn (pat):~ > cat grassdata/pat/PERMANENT/cell_misc/ortho_trento/gdal
file: /geodata2_originals_raid5/pat_OFD_RGB_IT2006_GB/060100.tif
band: 1
null: none
type: 1
GRASS 6.4.svn (pat):~ > cat grassdata/pat/PERMANENT/cellhd/ortho_trento
proj:       99
zone:       0
north:      5107440
south:      5101560
east:       1667640
west:       1660920
cols:       13440
rows:       11760
e-w resol:  0.5
n-s resol:  0.5
format:     0
compressed: 0
The same happens with a GeoTIFF without overviews..
And the same happens in GRASS 7.
Markus
